Grafana Enterprise: Grafana v11.1.0
Datasource is MongoDB -
Trying to achieve a visualization like shown in this video:
Grafana 11.1 release: new visualization features, Grafana Alerting updates, and more | Grafana Labs -
Following the steps outlined in the video -
What happened?
Options in documentation are not available even though same version (Grafana v11.1). As such, adding in the partition by values does not produce expected results as in the documentation. The Frame option is missing, and there are no field options available with “(base field name)”. As such there is no dynamic way to include all series in the partition dataset. Additionally there is no “Auto” option for Series mapping. Instead “Table” is available.
Options available would be the same as documentation
See attachments
*No -
