v11.1.0 on a raspberry debian bookworm -
Display only selceted Gauges
Hi everybody,
Please apologize any unconveniencies I make, as this is my very first post and I hope I can explain my problem:
I created a dashboard for our new photvoltaic plant, and after hours and hours I managed to have a acceptable time series visualization.
Data source is evcc → influxdb2.
In the next step I want to add gauges for the last input/output values of the system. This also works quite fine, but I want to reduce the gauges.
As “query source” for the gauges I chose “dashboard”, as I have made some transformation on the data which I don’t want to repeat for every panel. What happens is that all the gauges are displayed including the two un-transformed values.
- In the time series panel I was able to get rid of this by clicking on the labels one by one and thus select the desired series, but this method doesn’t work with the gauges.
- value options → fields only let’s me select all or just one field.
- In the Overrides-Section I didn’t find a property show/no show.
Here ist the gauge panel:
