And this causes confusion: XY Chart: Bug with threshold · Issue #64027 · grafana/grafana · GitHub
I am currently working with the XY Chart in Grafana v11.x and have come across the option to set thresholds by value. However, I am experiencing issues where this functionality does not seem to work as expected.
- Threshold Options in XY Chart: The UI provides options to configure thresholds by value, but these do not appear to affect the visualization. Is this functionality supported in the XY Chart, or is this a known issue?
- GitHub Discussions and Issues: I’ve noticed discussions suggesting that this might not be supported in the XY Chart. Could you provide official confirmation on whether threshold coloring by value is intended to work in the XY Chart in Grafana v11.x?
- Documentation Clarity: If the XY Chart does not support this feature, could you point out where in the documentation this is mentioned? It would be helpful for avoiding confusion among users.
I am looking for any guidance or clarification you can provide, as this impacts how we plan to use Grafana for our projects. Thank you for your support and for the continuous development of Grafana.
