Multi-select template variable combined with "Partition by Values" transformation causing dashboard to crash
Grafana v11.1.0
Datasource is MongoDB
  • Multi-select enabled template variable to filter an XY chart visualization with a “Partition by values” transformation.
  • Through the UI options.
  • What happened?
  • Dashboard becomes unstable, clicking edit panel on the visualization in the dashboard results in it crashing
  • That template variable dropdown selections wouldn’t crash a dashboard.
  • No configurations.
Error screen pops up (see below). Need to go back in browser to get dashboard back, all unsaved progress is lost.
An unexpected error happened
TypeError: Cannot read properties of undefined (reading ‘state’)
  • No.
