Hello.
I am making cpu utilization graph.
Value of the data is clearly 2.28, but the value of y-axis is wrong.
When i generate only 1 graph, the graph is clearly ok.
But when i generate 2 graphs in 1 view, I have this kind of problem.
Someone have any idea about this?
the value of Y-axis is not wrong. You’re using Graph Styles -> Stack Series option:
(in here stacking is off, you probably have stacking set to Normal). What that means is the series are put “on top of one another”, so the Y-axis shows the cumulative results, while the tooltip shows the result from just a single series.
