Grafana Cloud -
What happened?
The attachment is from the same Time Series.
The line 5minBS is werid.
In the same graphic and the same colum(5minBS) data.The dot at 09:14(-0.32) is correct. However, 09:27(-0.22) is incorrect.
I hav check the table view. The original data are correct.
How to fix the problem?
Thanks
