Right y-axis is setup to show Temperature. Data is there and aligned for right y-axis but the ya-axis is missing after saving and won’t show up even after enable / disable.
Grafena Version 6.4.0
Hi Ivana,
Thanks for your reply. Please see my screenshot at the beginning. The second series is assigned to the right y-axis using series override. It has shown up correctly once and then disappeared.
In the series color dialog , it doesn’t allow to enable “Use right axis”. Any idea why?
I was trying to recreate the bug, but unfortunately I wasn’t able to. Could you maybe tell me more about your settings
- Grafana version
- Data source type & version
- OS Grafana is installed on
- User OS & Browser
- Grafana plugins
- Others
And include panel json and query inspector request/response as well.
I recreated this panel from scratch, then it is working. I guess it might be a settings problem due to previous versions fo grafana. However, there are many others and I don’t want to rcreate all of them.
So try this one to enable right y-axis.
Blockquote
“datasource”: null,
“aliasColors”: {},
“bars”: false,
“dashLength”: 10,
“dashes”: false,
“fill”: 1,
“fillGradient”: 0,
“gridPos”: {
“h”: 8,
“w”: 24,
“x”: 0,
“y”: 61
“id”: 13,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: true,
“total”: false,
“values”: false
“lines”: true,
“linewidth”: 1,
“links”: ,
“nullPointMode”: “null”,
“options”: {
“dataLinks”:
“paceLength”: 10,
“percentage”: false,
“pointradius”: 2,
“points”: false,
“renderer”: “flot”,
“seriesOverrides”: [
“alias”: “Waschmaschine [Wh] [09-PSM-136]”,
“bars”: true,
“color”: “#56A64B”,
“lines”: false
“alias”: “Waschmaschine [W] [09-PSM-102]”,
“color”: “#FADE2A”,
“linewidth”: 2,
“zindex”: 0
“spaceLength”: 10,
“stack”: false,
“steppedLine”: true,
“targets”: [
“format”: “time_series”,
“group”: ,
“metricColumn”: “none”,
“rawQuery”: true,
“rawSql”: “SELECT\n ts AS "time",\n val as "Waschmaschine [W] [09-PSM-102]"\nFROM ts_number\nWHERE\n $__unixEpochFilter(ts / 1000) and (id = 102)\nORDER BY ts asc;”,
“refId”: “B”,
“select”: [
“params”: [
“value”
“type”: “column”
“timeColumn”: “time”,
“where”: [
“name”: “$__timeFilter”,
“params”: ,
“type”: “macro”
“group”: ,
“rawQuery”: true,
“rawSql”: “SELECT\n ts - (3600 * 1000) AS "time",\n val as "Waschmaschine [Wh] [09-PSM-136]"\nFROM ts_number\nWHERE\n $__unixEpochFilter(ts / 1000) and (id = 136)\nORDER BY ts asc;”,
“refId”: “A”,
“select”: [
“params”: [
“value”
“type”: “column”
“where”: [
“params”: ,
“type”: “macro”
“thresholds”: ,
“timeFrom”: null,
“timeRegions”: ,
“timeShift”: null,
“title”: “PSM09: Waschmaschine”,
“tooltip”: {
“shared”: true,
“sort”: 0,
“value_type”: “individual”
“type”: “graph”,
“xaxis”: {
“buckets”: null,
“mode”: “time”,
“name”: null,
“show”: true,
“values”:
“yaxes”: [
“format”: “locale”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
“format”: “short”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: false
“yaxis”: {
“align”: false,
“alignLevel”: null
Maybe if you could try to modify seriesOverride directly in your in your Panel JSON → add there "yaxis": 2 and save it → so it is going to be:
"alias": “Waschmaschine [Wh] [09-PSM-136]”,
"bars": true,
"color": “#56A64B”,
"lines": false,
"yaxis": 2
This works!
Thank you very much for your support.
I am very glad to hear that!
