Y Axis Unit Bug
Two time series metrics, value and timestamp for each. Both units are dollars. Placement left and placement right.
When both units are set to dollars it puts them both on the left Axis. I want one on the right and one of the left, only works if one of them is NOT unit dollars.
Bug? or am I doing it wrong?
Hi @tjw74
You are not doing this wrong. This is an ongoing issue and very much on the squad’s radar. Check out these issues for a larger discussion and some workarounds:
Thanks, appreciate the reply. I read through those threads. They are over complicating it and it’s still broke.
Just make a switch that says each metric has it’s own Y axis…and you should be able to resize and move your axis by dragging.
Just like ploty allows.
