Using the html/text panel , i have created a html form . On clicking the submit button , i need to insert the data to the database .
Can this be done in grafana ?
Replying to self : this can be achieved by invoking the grafana http api using ajax…
Hi, can you share what you did?
I need to insert data in a mysql from grafana too.
Thank You
Anyone have an idea how this was done? I’d like to be able to insert data also.
I made it doing a html form and then send it to a .php script on nginx, but is too much work I think, maybe the way with ajax is more easy.
