Wordmap Panel -
Hi Team,
Is it possible to add link in circle pointer in worldmap panel ?
Can we have any inbuilt option on the map to re-center it showing the location?
Angel
Dear @hemuangel17,
we added some regularly requested features to our fork of Worldmap already. The features you are asking for are called Fit to data and Clickthrough links.
Settings within control/edit screen
With kind regards,
Andreas.
Hi Amotl,
Thanks for your quick response.
I’m using 5.4 beta 1 version . In which worldmap version these functionality is available?
Angel
Any chance to upgrade to the most recent Grafana 6 release?
Not now. It will be upgraded during our next release.
We just installed Grafana Map Panel 0.7.0 on our production instance still running Grafana v5.4.4 and are able to confirm it works, see Luft: LDI / luftdaten.info Karte.
Hi Amotl,
Find the worldmap panel column in 5.4 beta version
Angel
Not following, sorry. The improved version of Worldmap is Grafana Map Panel.
Hey Thanks a lot . Can you help in getting the latest grafana map panel plugin zip file?
Dear @hemuangel17,
instructions on how to install the updated plugin are outlined at https://community.panodata.org/t/grafana-map-panel/121#setup. We are still working on keeping this up-to-date, see also Giving the Grafana Worldmap Panel some love.
With kind regards,
Andreas.
P.S.: We deleted the former post because it contained an outdated link pointing to an older release and we haven’t been able to update it.
