Why is my Worldmap panel having blocked out sections in the worldmap?
Grafana 7.5.7
Putting markers on the Worldmap panel in grafana of 1 object using “Static” as a datasource.
Installing Worldmap plugin, entering name/metric/latitude/longitude in table format.
  • What happened?
For some reason my Worldmap is showing blocks on several places on the map, when zooming this goes away but it just go to another place.
Yes: Timescale Documentation | Getting started with Grafana and Timescale
See image:
Thanks in advance.
Just a thought - but could it be an ad blocker in your browser?
If you check the console in your browser dev tools, are there any JavaScript or network errors?
There is a new Geomap panel that was introduced in Grafana 8.1 as a replacement for the Worldmap panel so that might also be worth a try if it is easily possible to upgrade your Grafana instance:
