I installed Prometheus and Grafana via Helm:
helm repo add prometheus-community https://prometheus-community.github.io/helm-charts
helm repo update
helm install prometheus prometheus-community/prometheus
helm repo add grafana https://grafana.github.io/helm-charts
helm repo update
helm install grafana grafana/grafana
Forwarding
export POD_NAME=$(kubectl get pods --namespace default -l "app.kubernetes.io/name=prometheus,app.kubernetes.io/instance=prometheus" -o jsonpath="{.items[0].metadata.name}")
kubectl --namespace default port-forward $POD_NAME 9090
export POD_NAME=$(kubectl get pods --namespace default -l "app.kubernetes.io/name=grafana,app.kubernetes.io/instance=grafana" -o jsonpath="{.items[0].metadata.name}")
kubectl --namespace default port-forward $POD_NAME 3000
Expose services
kubectl expose service prometheus-server --type=NodePort --target-port=9090 --name=prometheus-server-ext
kubectl expose service grafana --type=NodePort --target-port=3000 --name=grafana-ext
When I login to Grafana(http://localhost:3000) and add data source with Prometheus
I got this error:
Post “http://localhost:9090/api/v1/query”: dial tcp 127.0.0.1:9090: connect: connection refused - There was an error returned querying the Prometheus API.
But I can access localhost:9090 from browser.
The kubernetes services are:
kubectl get services
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
kubernetes ClusterIP 10.43.0.1 <none> 443/TCP 1d
prometheus-alertmanager-headless ClusterIP None <none> 9093/TCP 1h
prometheus-server ClusterIP 10.43.39.133 <none> 80/TCP 1h
prometheus-prometheus-pushgateway ClusterIP 10.43.199.209 <none> 9091/TCP 1h
prometheus-prometheus-node-exporter ClusterIP 10.43.246.176 <none> 9100/TCP 1h
prometheus-alertmanager ClusterIP 10.43.28.143 <none> 9093/TCP 1h
prometheus-kube-state-metrics ClusterIP 10.43.228.89 <none> 8080/TCP 1h
prometheus-server-ext NodePort 10.43.104.42 <none> 80:30186/TCP 1h
grafana ClusterIP 10.43.208.205 <none> 80/TCP 1h
grafana-ext NodePort 10.43.55.78 <none> 80:32765/TCP 1h
How to set Prometheus server URL correctly?
