I am setting up Grafana on Kubernetes with some custom dashboards and Prometheus as default data source.
All services are running behind Traefik. Prometheus is running at https://myapp.dev/svc/prometheus/ and Grafana is running at https://myapp.dev/svc/grafana/
I can login to both grafana(also able to see dashboards that were added to config) and prometheus, however when I test the Prometheus datasource, I see the following error in grafana logs:
lvl=eror msg="Data proxy error" logger=data-proxy-log userId=1 orgId=1 uname=xxx path=/api/datasources/proxy/1/api/v1/query remote_addr=192.168.64.1 referer=https://myapp.dev/svc/grafana/datasources/edit/1/ error="http: proxy error: dial tcp: lookup prometheus on 10.96.0.10:53: no such host"
Grafana deployment
kind: Deployment
apiVersion: apps/v1
metadata:
namespace: default
labels:
app: grafana
spec:
replicas: 1
selector:
matchLabels:
app: grafana
template:
metadata:
labels:
app: grafana
spec:
containers:
- name: grafana
image: grafana/grafana:latest
ports:
- containerPort: 3000
volumeMounts:
- mountPath: /etc/grafana/provisioning/datasources/
- mountPath: /etc/grafana/provisioning/dashboards/
- mountPath: /var/lib/grafana
volumes:
- name: grafana-storage
emptyDir: {}
- configMap:
defaultMode: 420
- configMap:
defaultMode: 420
Configmap
kind: ConfigMap
apiVersion: v1
metadata:
data:
datasource.yml: |-
apiVersion: 1
datasources:
- name: Prometheus
type: prometheus
orgId: 1
access: proxy
url: http://prometheus:9090/svc/prometheus/
basicAuth: false
I am not sure on how to fix this error and test Prometheus datasource.
