I am using elasticsearch v1.7.3, any one could suggest that which version of grafana can support elasticsearch 1.7.x? I just installed the latest 4.5.1 and find it just gives 2 options of elasticserach 2.x, 5.x
Thanks in advance.
Thanks in advance.
not sure, try Grafana v3.1
Thanks torkel, v3.1 works
lower than version 4.1, there was a change to add elastic5 and remove elastic 1
