For influxdb 1.x and influxql one could provide an alias to give time series a name in the legend.
For influxdb 2.x and flux I could not find any similar.
How can I give each series a name of my choice please or get only certain parts of the default description?
E.g. I only want to show cpu-total, cpu0 and cpu1 instead of the whole usage_system {cpu=…
is nobody available who can help here?
Still need help please.
Did you try to use tags ?
Good Luck
Hi wlargou,
thanks - I’m glad to get some help here.
Are you sure tags will work together with influxdb 2.0 flux queries?
I do not know what tags are and how to use them.
Even google did not really help.
Could you give me some hints to get started with tags so I can give it a try?
Alias patterns
- $m = replaced with measurement name
- $measurement = replaced with measurement name
- $col = replaced with column name
- $tag_exampletag = replaced with the value of the
exampletag tag. The syntax is $tag_yourTagName (must start with $tag_ ). To use your tag as an alias in the ALIAS BY field then the tag must be used to group by in the query.
- You can also use [[tag_hostname]] pattern replacement syntax. For example, in the ALIAS BY field using this text
Host: [[tag_hostname]] would substitute in the hostname tag value for each legend value and an example legend value would be: Host: server1 .
Source : InfluxDB | Grafana Labs
It’s a bit tricky though.
Good Luck
sorry for replying so lately - but I am quite busy now.
Thanks - I ill try that.
But I can’t beleive taht it is much more complicated compared to influxql.
