Grafana version: v9.4.3 -
I am trying to get the ingestion data for Metrics and Traces using the metrics:container_network_receive_bytes_total -
I have the below queries for:
Metrics:
sum(increase(container_network_receive_bytes_total{cluster="$cluster",namespace="$namespace",pod=~".*vmsingle.*"}[$__range]))/1024/1024/1024
Traces:
sum(increase(container_network_receive_bytes_total{cluster="$cluster",namespace="$namespace",pod=~".*jaeger.*"}[$__range]))/1024/1024/1024
When I run the above two queries, I get the ingestion data for Metrics and Traces in GBs. -
What happened?
For time range involving more than 20 days, the data is empty and it shows “No data”. But when I try to query it in chunks (i.e 10 days + 10 days, I get the data). -
When the queries are run, the ingestion data for Metrics and Traces should be shown in GBs, no matter what the Time range is. -
No errors in Grafana UI. Even the Query Inspector says:
"range": { "from": "2023-09-30T18:30:00.000Z", "to": "2023-10-21T18:29:59.000Z", "raw": { "from": "2023-09-30T18:30:00.000Z", "to": "2023-10-21T18:29:59.000Z" } }, "from": "1696098600000", "to": "1697912999000" }, "hideFromInspector": false. },
“response”: {
“results”: {
“A”: {
“status”: 200,
“frames”: ,
“refId”: “A”
