Hello Grafana Community,
I’m facing an issue with one of my Grafana dashboards where the panel shows “No data” shortly after a fresh ingestion completes. Here’s a bit of context:
- I have a scheduled job that ingests fresh data every 15 minutes.
- The Grafana panel is set to use the “Instant” query type.
- The data displays correctly initially after ingestion, but after about 5 minutes, it stops showing any data until the next ingestion cycle.
The reason I’m using the Instant query type is that when I use the Range query, I get duplicate records in the results. By switching to Instant, I’m able to avoid these duplicates, but this causes the panel to show “No data” between ingestion cycles.
Has anyone encountered a similar issue, or is there a recommended way to deal with this problem? Any insights or suggestions would be greatly appreciated!
