10.4.0 - What are you trying to achieve?
collect metrics of disk storage per vmware - How are you trying to achieve it?
using plugin of Vmware vSphere in influxdb - What happened?
code of this variable not found - What did you expect to happen?
have the of disk storage per vmware using telegraf in influxdb - Can you copy/paste the configuration(s) that you are having problems with?
no - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
no - Did you follow any online instructions? If so, what is the URL?
no
Hello @tonywanna98,
What do you mean by:
Can you show what your influxdb base looks like (if you can’t share the data, at least the fields). What version of influxdb are you using?
Also, are you sure Grafana is the good place to ask your question? If the problem comes from influx or vmware I think you’d better ask your question on influx community or vmware community.
Regards
