Hello im very new to grafana und want to show the Disk Usage of the /var/ partition of my openbsd system.
I´ve got two fields in my InfluxDB
storageSize.var
storageUsed.var
Kind regards,
Michael
storageSize.var
storageUsed.var
Kind regards,
Michael
Can you explain how much you have set up already?
The applications are running (Grafana,InfluxDB & Telegraph). Ivo got those two fields in the Database but i have problems to build a panel where Grafana shows me the percent value. I found out that there are systems where you can read the disk usage in percent via snap oid but my system does not have this option.
