10.0.3 -
I have a video wall made of 72 LED panels, laid out in a grid 12x6. I’d like to monitor the temperature of each panel in a way that makes sense visually, so that if one panel overheats, it’s easy to identify its location. Here’s an image of how I want it to look:
This data is coming from Prometheus SNMP and each metric is labeled with its Port ID and Unit ID, representing column and row, respectively. The data looks like this:
ledTemperatureUnitCelsiusAmbient{ledCellStatusPortId="12",ledCellStatusUnitId="1"} 20.8
ledTemperatureUnitCelsiusAmbient{ledCellStatusPortId="12",ledCellStatusUnitId="2"} 24
ledTemperatureUnitCelsiusAmbient{ledCellStatusPortId="12",ledCellStatusUnitId="3"} 26.1
ledTemperatureUnitCelsiusAmbient{ledCellStatusPortId="12",ledCellStatusUnitId="4"} 26.7
ledTemperatureUnitCelsiusAmbient{ledCellStatusPortId="12",ledCellStatusUnitId="5"} 27.3
ledTemperatureUnitCelsiusAmbient{ledCellStatusPortId="12",ledCellStatusUnitId="6"} 27.8
In Grafana, I created a table with the query:
max(ledTemperatureUnitCelsiusAmbient{instance="10.49.51.10"}) by(ledCellStatusPortId,ledCellStatusUnitId) with type=instant and format=table.
I used “organize fields” transformation to remove time and value.
What happened?
I have a table with 72 rows (one per metric) and 3 columns (port, unit, value). -
I want to have 6 rows and 12 columns, with each cell containing only the value. -
No -
I tried following instructions from here: Bi dimensional matrix table display from Prometheus query
But the “outer join” and “labels to fields” transformations both have no effect.
