I come across to table panel picture in the Grafana document:
However, I can’t figure out how to do exactly like that. Could anyone please help to provide some hints?
Thanks… !
table-panel7|690x206
Thanks… !
Hi @rsuhendro - the different coloring in cells for certain values is set using the Thresholds feature: https://grafana.com/docs/grafana/latest/panels/thresholds/#add-a-threshold
If you are using Grafana version > 7, then here’s example with Prometheus
@anon80964540, @dykow, thanks a lot for the hints…
I get it:
