brynn
May 6, 2019, 12:21am
1
Hi there,
I have a prometheus datasource.
I have 2 panels: regions and cloud_provider, and I have a load value.
I would like to have regions on X axis, cloud_provider and Y axis giving me load value.
I’m not able to have this. every think I’m doing leaving me with regions and cloud_provider as columns, and the row is always time series.
I’m only looking to show the last value.
Thanks for any help!
bala
May 7, 2019, 3:40am
2
I use and recommend https://grafana.com/plugins/yesoreyeram-boomtable-panel . This is very helpful and easy to use.
Regards,
Bala.
brynn
May 8, 2019, 2:12pm
3
I gave it a try but was not able to map the row and column correctly. many of the examples I saw online was not using prometheus.
Do you have any relevant link I can follow to understand the steps?
bala
June 19, 2019, 8:21am
4
I used influxdb as my data source and no experience on Prometheus.
The developer of this plugin usually checks and reverts on the issues posted. Below is the url
