So here is a question that I am guessing there is a very simple answer to that i am just missing.
I have a panel that shows data based on current metric value, previous 1m, and previous 2m (using offset). I have a query that shows a marker when the current value is above the previous 2 values (meaning rising for 3 minutes). This works well when i am looking at up to the last 2 days, but when i change to 7 or 30 days, i believe grafana is using a different aggregation interval and i dont see my marker (as well my averages shown drop dramatically). Again, i suspect this is because when showing longer intervals grafana is using a different aggregation, which i suspect is quite normal. I guess my question is then that i want to visual 30 days of data but at the same granularity as when i am showing 1 hour?
