v7.5.7 -
have a 2 minutes(low granularity) graph and then be able to aggregate that up for the per day view. -
Using grafana graphs and panels -
What happened?
I have a low granularity graph (at 2mins) that has one spike of value 3 but then when I want to aggregate this for a day view I don’t get 3, I get 5 and it is the same search just changed interval to1d. -
I expect in the 1 day view graph to show 3, as a bar chart or line. No matter the visulaisation the value should be the same. -
graphs are exactly the same with only difference being the change in interval.
graph on left shows value 3 at 2min granularity (interval set to auto)
grah on right has a value of 5(?) but what the x-axis o be in a d e.g. 01/06 (interval set to 1d)
NA -
No
basically I am trying work out why the value in right hand graph is not 3 and how to change the x-axis to a day view e.g. 01/06.
view of panel edit with only change being the interval
