Hello people
I have a time series graph and it’s showing the information correct. However the interval showing in the axis is 5 minutes.
I would like to have the interval in the graph as 1 minute. Is that possible?
How?
My visualization will show always max range of 1 hour. So I would like to have 60 intervals showing in the axis.
see image attached
Using Grafana Cloud -
I want to change the granularity of a time series visualization to 1 minute instead of 5 minutes (see image) -
I`m trying to find options in the plugin setup. didn’t find yet
