Visualisation issue with IOS 16.3.1
Hello Community,
after IOS update to 16.3.1 some dashboard elements not vissible.
I testet different browsers but always the same issue.
any ideas?
Thanks
Bye
Such as which?
Such as what?
any ideas?
Any details?
Thanks
Bye
Regards,
Antony.
… I found out it is dependent where the elements are positioned. On my desktop computer looks it well.
But on the mobile phone some panels are not vissible. And bevor i did the update was all good.
When I Move the panel on a other pos is it vissible but other panel are not vissible. Its a crazzy behavior.
I testet it with Firefox, Safari, Chrome
thanks
Lars
… when i go to the view option (panel in full screen mode) is it vissible. If i go back all panels are vissible without failures.
When I reload the dashbord some panels are not vissible.
It is hard to describe the behavior :slight_smile:
crazzy crazzy
i have exactly the same issue. when i switch my browser on the iphone to desktop mode the strange behaviour does not change. when i turn my iphone to landscape mode it displays all grafana objects but the scaling is not very well done….
Hi community members :wave:
A quick update on this case:
There is recently an issue filed at our GitHub repository (link to the post)
We would recommend that all of you can provide some more data and information such as:
  • logs
  • screenshots
  • iOS version
  • browser name+version
  • browser network data as .HAR file if possible
as overall it seems like Grafana UI does not work well with iPhone.
Your feedback on this issue will be useful for Engineers to improve the quality !! :pray:
Lastly, please subscribe to the above issue to get up-to-date news on the fix or a possible workaround.
Thank you :slight_smile:
