Hi all,
I’m on Grafana Cloud free service.
I’m playing with a simple dashboard… and would like to insert a short of HTML link button to another dashboard, but I won’t use the links variables in this case… but something like an HTML element to link directly to a second dash with some variable into the URL.
I found 2 plugs:
but it seems to me that their use is to communicate via REST and not to be used as a simple HTML link.
Do I have to use the HTML panel? Is there no other way to do it?
Can you give me a courteous answer and perhaps an example.
Thank you and good job to everybody.
ALEN
