I am trying to add a link to a dashboard from another panel. Please see example in the screenshot. Ideally, I shouldn’t be having to provide “localhost” there… and should just be able to say … <dashboard-folder/dashboard-name>. Does grafana have a way to do this?
Latest -
Referencing a dashboard as a hyperlink from another panel’s text -
see screenshot -
What happened?
screenshot attached -
