Dashboard links only works after site reload
    v8.1.5 OSS
    I want to use link urls in my dashboards, which links to different dashboards. Fore example, I’ve got a dashboardds, which shows the resource usage of the entire kubernetes cluster. In this dashboard there is a panel which lists all the namespaces. Clicking on one of these namespaces should redirect you to a dashboard which shows the details of the selected namespace.
    Redirections using linkUrl:
"linkUrl": "./d/85a562078cdf77779eaa1add43ccec1e/kubernetes-compute-resources-namespace-pods?orgId=1&refresh=10s&var-datasource=$datasource&var-cluster=$cluster&var-namespace=$__cell",
  • What happened?
    For example, when clicking on namespace “default” it redirects me to the following path:
/d/85a562078cdf77779eaa1add43ccec1e/kubernetes-compute-resources-namespace-pods?orgId=1&refresh=10s&var-datasource=default&var-namespace=default
But it shows a 404 Page not found error. When hitting F5 or refreshing the page the expected dashboard is shown.
    The dashboard should be shown without needing to refresh the page.
    Here’s the entire panel json:
  "id": 8,
  "gridPos": {
    "x": 0,
    "y": 13,
    "w": 24,
    "h": 7
  "type": "table-old",
  "title": "CPU Quota",
  "datasource": "$datasource",
  "thresholds": [],
  "links": [],
  "legend": {
    "avg": false,
    "current": false,
    "max": false,
    "min": false,
    "show": true,
    "total": false,
    "values": false
  "aliasColors": {},
  "dashLength": 10,
  "fill": 1,
  "lines": true,
  "linewidth": 1,
  "nullPointMode": "null as zero",
  "pointradius": 5,
  "renderer": "flot",
  "seriesOverrides": [],
  "spaceLength": 10,
  "styles": [
      "alias": "Time",
      "dateFormat": "YYYY-MM-DD HH:mm:ss",
      "pattern": "Time",
      "type": "hidden",
      "align": "auto"
      "alias": "Pods",
      "colorMode": null,
      "colors": [],
      "decimals": 0,
      "link": true,
      "linkTargetBlank": false,
      "linkTooltip": "Drill down to pods",
      "linkUrl": "./d/85a562078cdf77779eaa1add43ccec1e/kubernetes-compute-resources-namespace-pods?orgId=1&refresh=10s&orgId=1&refresh=10s&var-datasource=$datasource&var-cluster=$cluster&var-namespace=$__cell_1",
      "pattern": "Value #A",
      "thresholds": [],
      "type": "number",
      "unit": "short",
      "align": "auto"
      "alias": "Workloads",
      "colorMode": null,
      "colors": [],
      "decimals": 0,
      "link": true,
      "linkTooltip": "Drill down to workloads",
      "linkUrl": "./d/a87fb0d919ec0ea5f6543124e16c42a5/k8s-resources-workloads-namespace?var-datasource=$datasource&var-cluster=$cluster&var-namespace=$__cell_1",
      "pattern": "Value #B",
      "thresholds": [],
      "type": "number",
      "unit": "short",
      "align": "auto"
      "alias": "CPU Usage",
      "colorMode": null,
      "colors": [],
      "decimals": 2,
      "link": false,
      "linkTooltip": "Drill down",
      "linkUrl": "",
      "pattern": "Value #C",
      "thresholds": [],
      "type": "number",
      "unit": "short",
      "align": "auto"
      "alias": "CPU Requests",
      "colorMode": null,
      "colors": [],
      "decimals": 2,
      "link": false,
      "linkUrl": "",
      "pattern": "Value #D",
      "thresholds": [],
      "type": "number",
      "unit": "short",
      "align": "auto"
      "alias": "CPU Requests %",
      "colorMode": null,
      "colors": [],
      "decimals": 2,
      "link": false,
      "linkUrl": "",
      "pattern": "Value #E",
      "thresholds": [],
      "type": "number",
      "unit": "percentunit",
      "align": "auto"
      "alias": "CPU Limits",
      "colorMode": null,
      "colors": [],
      "decimals": 2,
      "link": false,
      "linkUrl": "",
      "pattern": "Value #F",
      "thresholds": [],
      "type": "number",
      "unit": "short",
      "align": "auto"
      "alias": "CPU Limits %",
      "colorMode": null,
      "colors": [],
      "decimals": 2,
      "link": false,
      "linkUrl": "",
      "pattern": "Value #G",
      "thresholds": [],
      "type": "number",
      "align": "auto"
      "alias": "Namespace",
      "colorMode": null,
      "colors": [],
      "decimals": 2,
      "link": true,
      "linkUrl": "./d/85a562078cdf77779eaa1add43ccec1e/kubernetes-compute-resources-namespace-pods?orgId=1&refresh=10s&var-datasource=$datasource&var-namespace=$__cell",
      "pattern": "namespace",
      "thresholds": [],
      "type": "number",
      "unit": "short",
      "align": "auto"
      "alias": "",
      "colorMode": null,
      "colors": [],
      "decimals": 2,
      "pattern": "/.*/",
      "thresholds": [],
      "type": "string",
      "unit": "short",
      "align": "auto"
  "targets": [
      "expr": "sum(kube_pod_owner) by (namespace)",
      "format": "table",
      "instant": true,
      "intervalFactor": 2,
      "legendFormat": "",
      "refId": "A",
      "step": 10
      "expr": "count(avg(namespace_workload_pod:kube_pod_owner:relabel) by (workload, namespace)) by (namespace)",
      "format": "table",
      "instant": true,
      "legendFormat": "",
      "refId": "B",
      "step": 10
      "expr": "sum(node_namespace_pod_container:container_cpu_usage_seconds_total:sum_rate) by (namespace)",
      "format": "table",
      "instant": true,
      "legendFormat": "",
      "refId": "C",
      "step": 10
      "expr": "sum(kube_pod_container_resource_requests{resource=\"cpu\",unit=\"core\"}) by (namespace)",
      "format": "table",
      "instant": true,
      "legendFormat": "",
      "refId": "D",
      "step": 10
      "expr": "sum(node_namespace_pod_container:container_cpu_usage_seconds_total:sum_rate) by (namespace) / sum(kube_pod_container_resource_requests{resource=\"cpu\",unit=\"core\"}) by (namespace)",
      "format": "table",
      "instant": true,
      "legendFormat": "",
      "refId": "E",
      "step": 10
      "expr": "sum(kube_pod_container_resource_limits{resource=\"cpu\",unit=\"core\"}) by (namespace)",
      "format": "table",
      "instant": true,
      "legendFormat": "",
      "refId": "F",
      "step": 10
      "expr": "sum(node_namespace_pod_container:container_cpu_usage_seconds_total:sum_rate) by (namespace) / sum(kube_pod_container_resource_limits{resource=\"cpu\",unit=\"core\"}) by (namespace)",
      "format": "table",
      "instant": true,
      "legendFormat": "",
      "refId": "G",
      "step": 10
  "tooltip": {
    "shared": false,
    "sort": 0,
    "value_type": "individual"
  "transform": "table",
  "xaxis": {
    "buckets": null,
    "mode": "time",
    "name": null,
    "show": true,
    "values": []
  "yaxes": [
      "format": "short",
      "label": null,
      "logBase": 1,
      "max": null,
      "min": 0,
      "show": true
      "format": "short",
      "label": null,
      "logBase": 1,
      "max": null,
      "min": null,
      "show": false
  "showHeader": true,
  "columns": [],
  "fontSize": "100%",
  "sort": {
    "col": 0,
    "desc": true
  "bars": false,
  "dashes": false,
  "percentage": false,
  "points": false,
  "stack": false,
  "steppedLine": false,
  "timeFrom": null,
  "timeShift": null,
  "pageSize": null
    Grafana is showing it’s 404 page.
    In chrome’s console it shows following errors:
runRequest.ts:149 runRequest.catchError {type: "cancelled", cancelled: true, data: null, status: -1, statusText: "Request was aborted", …}
hostReportError.js:3 Uncaught e {message: "no elements in sequence", name: "EmptyError"}
I have the same situation with Grafana 8.1.6. When i right click on it and open the link in a new tab it’s works so I don’t understand what’s happening
I‘ve fixed it!
I only had to remove the leading dot:
./d/….
/d/…..
This worked for me
