Vertical time series plugin
I work in the energy sector and we need vertical time series panels in which time is on the y-axis and values ​​on the x-axis in addition to the line growing upwards. I would like to know if there is a community plugin specifically for this purpose because using the standard timeline plugin, in addition to requiring a lot of configuration and adaptation, is not reliable and generates several errors.
You might want to look at Business Chart pluing for that
Thanks, I’ll take a look and run some tests.
