Hello. I’m using Grafana dashbord. I gather voltage data and i want to write a battery percentage matching with voltage. I’m using “value mapping”. But it doesn’t work. Display text never comes. I see still same voltage values, not display text.
Hi @sezerkiral
Can you please share your entire dashboard json inside one code block?
There are other ways to calculate values like percentage from data, and those might work better for you rather than hard-coding everything like this
