Value map for !=0
Hello.
I’m trying to create a simple visualization that displays either the word “Success” or “Failure”. I’m using value mappings in a stat panel. When the value is 0, it properly displays the text “Success”. For the 2nd mapping, I would like “not equal zero” to catch any other value and display text “Failure”. Instead, displays the numeric value.
I set:
And for value 0 I get:
But for any value other than 0, I get the original unmapped value:
I’m likely missing something obvious. Any/all help is appreciated.
Peace.
    Version 11.4.0
    Ubuntu 22.04
    A a “stat” visualization with value-mapping where:
    Value 0 Success
    Value !=0 Failure
    I have tried value mappings of:
    Value !=0
    Regex [^0]+
    Regex *
  • What happened?
    It displays the number of the value, not the display text setting of “Failure”. My mapping for “Value = 0” does display the text “Success”.
    Display either the text “Success” or “Failure”
    See photos above
    Configure value mappings | Grafana documentation
try range value 1 to 99999999999999999999999999
does it also include negative values below 0?
I saw “range”, and that could work absent the real logic I’m hoping for. “From 1 to infinity” is not the same as “not equal zero”. What if the value ends up being nonsense? Or non-numeric garbage?
It is also possible that I’m an old BOFH, and should just let this go :slight_smile:
Au contraire mon amie! So you use Value map for !=0 and value = 0 but now you object with what if it is non numeric? :wink: Simon Travaglia objects!
Did you try Regex?
I did try regex, yes. Strange, I’m getting different behavior than you are.
Exact same regex, but for me it displays the vale, un-mapped. I’m using Version 11.4.0.
please share your raw datasource, obfuscated if needed
The data is coming from Prometheus’ textfile collector. I have placed the following file:
root@mynode:/var/lib/node_exporter/textfile_collector# cat job_exit_status.prom
job_exit_status 127
Prometheus sees it as:
so the value 127 is numeric so the regex is not happy. if the value is ‘127’ string it works. so maybe that [^0]+ works purely on string values?
I tried on numeric values (see Table view):
mapping
If I add single or double quotes to the value in my .prom file, prometheus no longer picks up the metric:
job_exit_status '127'
I then get in Prometheus:
Also, fwiw, I am able to set an alert with the logic that I want:
That will fire on anything that is “not zero”.
For additional info. I have also set:
I have also toggled the “Unit” between Misc/Number and Misc/String. Either way, it still displays “127”.
Your value will always be > 0 (because it’s a counter) and a number (because Prometheus can only store numbers). You should use a range.
