Value Mapping doesn’t work
Grafana v10.1.5, hosted locally on linux machine.
Light up cells in a table visualization panel with red coloured text when their value is equal to “FAIL”.
I added the following rule in value mappings:
I tried to do the same for specific column using Override, but it didn’t work either.
  • What happened?
Nothing.
Text changes colour.
SQL query:
            SELECT
                execution_time,
                build,
                result,
-- some more fields
            FROM
                metadata
            WHERE
-- some filters
            ORDER BY
                execution_time DESC;
Mappings defined as:
          "mappings": [
              "options": {
                "FAIL": {
                  "color": "dark-red",
                  "index": 0,
                  "text": "failing"
                "PASS": {
                  "color": "dark-green",
                  "index": 1,
                  "text": "passed!"
              "type": "value"
No errors.
Shame to admit but I had an override for one of the columns that I overlooked.
What I also forgot to add was Cell type override, see:
I guess one sometimes needs fresh eyes and right question asked by another person:)
Thanks for you help!
you can follow our detailed documentation for fix this problem
Hy , just wanted to check, does my solution work for you, or are you still facing same issues Please contact me if you need any help, I will be happy to help you here.
