8.3.6 in Docker -
I want to have table cells coloured by a value mapping -
I try to use the Overwrite Value mapping -
What happened?
The cell colour does not change -
That the cell colour is changing according to the value mapping -
Table + overwite:
Overwrite config:
No -
Configure value mappings | Grafana documentation
You need to set also cell coloring mode (e. g. bacground) in the panel config.
