V10.4.0 -
Create a dashboard that displays colored success or failure messages based on logs ingested by Loki. -
The logs have specific begin, Success, And Failure lines in them. I query for those and then have a line Field that show the line. -
What happened?
When I attempt to use Value Mappings to Change the value for the Line Field, it doesn’t work. Regex or Exact Value. Neither change it. I’ve displayed it as a Stat and as a Table. The text stays as the original value the query brought in. -
The value would change from what the query brought in, to what I put in replace. -
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. None.
Did you follow any online instructions? If so, what is the URL? Just what was in the Grafana Documentation.
can you try a convert filed type transform to convert the field to a string, then the value mappings should work
Nevermind. I got it. Seems there was a carriage return sneaking in from the query I didn’t see. Worked once I tweak the Regex. Thanks for helping!
