Grafana v11.2.1 (086b47f098) -
Add some style/color to business table visualization -
I want to set the GREEN color to Result column where text is Pass and RED color to Result column where text is Fail
I have tried to achieve this by using Value mappings:
What happened?
Color did not change -
Change the color of the Result column based on text
Perhaps someone could share some insights on how this can be achieved? Thanks in advance
