I am a newbie with grafana and I have created aws data pipeline dashboard there is a column called status and values are Healthy and Error. healthy in a cell then it will be green if it comes to Error it should be red. i don’t know how to do that. can someone help me with this?
Thanks
Hello
and welcome to the forum, @pawanyoda
It sounds like Grafana’s Value Mapping feature might work for this. Have you checked out the docs on it?
Hi [mattabrams]
i have checked this option but not working for me.
Grafana Vesrion: Grafana v8.3.0
this is solved with both value mapping and then goto override column and add property cell display and choose color as you want. it working.
