How to map values to percentages?
I’m running Grafana 11.2 on a Raspberry Pi 4B
I want to have a % display of how full my water tank is.
the sensor measures in ohms from 0 to 246.
On a dashboard i would like to see 0% (empty) through to 100% (full) at 1 % intervals.
I want to show this on a gauge, and also on a timeline so we can see how much water is being used when.
I assumed i would be able to use something in Value Mapping, but i cant see how i could make that work there… is there something within the query that needs to be added?
Current query is below, that shows the ohms value
from(bucket: "db1")
  |> filter(fn: (r) => r["_measurement"] == "tanks.fuel.fuel starboard.senderResistance")
  |> filter(fn: (r) => r["context"] == "vessels.urn:mrn:signalk:uuid:ea14781e-5714-4706-8f81-24b2a995e8a1")
  |> filter(fn: (r) => r["_field"] == "value")
  |> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
  |> yield(name: "last")
thanks
Colin
Add this line below |> aggregateWindow and above |> yield
|> map(fn: (r) => ({ r with "Percentage ( % )" : float(v: r.column01) / float(v: r.column02) * 100.0 }))
thanks for the super fast response. I tried what you said but im not getting the correct value. The value in the dashboard is 2.48.
The current ohm value is 2.478027344
It looks like the output is a truncated version of the ohm value?
query:
from(bucket: "db1")
  |> yield(name: "last")```
thanks
np :slight_smile:
ps. You do have to change r.column01 and r.column02 with your own fields/colums :wink:
I wasn’t sure for what values you wanted to calc. percentage so I used those for the example
So in your case something like?
|> map(fn: (r) => ({ r with "Percentage ( % )" : float(v: r["_field"]) / float(v: r["_measurement"]) * 100.0 }))
and other wise r._field instead of r["_field"]
Maybe you have to add “override” to the new mapped column to get the correct amount of decimals.
Hi, I don’t think it’s a decimal issue.
The original (ohm) value is 2.48, the percentage for this should be around 8% i think, given the full range is 0-246.
I’m not getting the 8% though. Did I amend the query correctly?
@colinb6d1
Hmmm is that approach correct?
If the full range is 246 meaning that is 100% , then 1% == 2.46.
2.48 / 246 * 100 = 1.008130081300813 %
So if it should be closer to 8% something in your query is off.
aha i missed this msg :frowning:
i’m still confused with the query statement itself.
i know my minimum is 0 and my max is 245.
i know i want to map 0 - 0 and 265 - 100 and everything in between.
In the query you suggested, what specifies that the max is 245?
i used this:
from(bucket: "db1")
  |> map(fn: (r) => ({
      r with _value: (r._value / 246.0) * 100.0
  |> yield(name: "last")
which gave me the outcome i was looking for :slight_smile: thanks for your help though.
