Show Gauge percentage based on conditions
    v6.5 and Windows 10
    I have a gauge which should show Healthy (100%) when some condition say A and B are true, Partial Healthy (50%) when some condition C and D are true else 0%
For Ex. -
sum by (field1, field2)(metric1{field1="$field1",field2="$field2"}) == 0 OR sum by (field1, field2)(metric2{field1="$field1",field2="$field2"}) then Gauge → 100%
sum by (field1, field2)(metric3{field1="$field1",field2="$field2"}) == 0 OR sum by (field1, field2)(metric4{field1="$field1",field2="$field2"}) then Gauge → 50%
    I am not sure how this can be achieved. With PromQL query, can we show some values based on when some condition is true?
  • What happened?
Can you screenshot you data in the table panel? Or share the raw query request and response? You can find it in the inspect drawer in the panel dropdown.
You should be able to accomplish this using value mappings:
