V5.4.2 : Alert always returns no data from InfluxDB in some graphs
I have a query that works fine to plot graph. But when i enable Alert, the condition always returns ‘No Data’. I enabled debug log in grafana and captured the InfluxDB query that is sent when Test Rule is clicked. It is as below
url=“http://x.x.x.x/query?db=mydb&epoch=s&q=SELECT+“rx-util__data”+FROM+“Cisco-IOS-XR-pmengine-oper%3Aperformance-management%2Fethernet%2Fethernet-ports%2Fethernet-port%2Fethernet-current%2Fethernet-second30%2Fsecond30-ethers%2Fsecond30-ether”+WHERE+(“Producer”+%3D+‘cvt-one-guru’+AND+“name”+%3D+‘HundredGigECtrlr0%2F0%2F0%2F2’)+AND+time+>+now()+-+1m
Same query succeeds to return output via web browser as below.
{“results”:[{“statement_id”:0,“series”:[{“name”:“Cisco-IOS-XR-pmengine-oper:performance-management/ethernet/ethernet-ports/ethernet-port/ethernet-current/ethernet-second30/second30-ethers/second30-ether”,“columns”:[“time”,“rx-util__data”],“values”:[[1590004269,“100.00”],[1590004279,“100.00”],[1590004289,“100.00”],[1590004299,“100.00”],[1590004309,“100.00”],[1590004319,“100.00”]]}]}]}
But the output from Alert page is as below
firing:false
state:“no_data”
conditionEvals:“false = false”
timeMs:“1.016ms”
logs:Array[2]
0:Object
message:“Condition[0]: Query Result”
data:Array[1]
0:Object
name:“Cisco-IOS-XR-pmengine-oper:performance-management/ethernet/ethernet-ports/ethernet-port/ethernet-current/ethernet-second30/second30-ethers/second30-ether.rx-util__data”
points:Array[6]
0:Array[null,1590005939]
1:Array[null,1590005949]
2:Array[null,1590005959]
3:Array[null,1590005969]
4:Array[null,1590005979]
5:Array[null,1590005989]
1:Object
message:“Condition[0]: Eval: false, Metric: Cisco-IOS-XR-pmengine-oper:performance-management/ethernet/ethernet-ports/ethernet-port/ethernet-current/ethernet-second30/second30-ethers/second30-ether.rx-util__data, Value: null”
data:null
Pasting output from query inspector:
xhrStatus:“complete”
request:Object
method:“GET”
url:“api/datasources/proxy/1/query”
params:Object
db:“mydb”
q:“SELECT “rx-util__data” FROM “Cisco-IOS-XR-pmengine-oper:performance-management/ethernet/ethernet-ports/ethernet-port/ethernet-current/ethernet-second30/second30-ethers/second30-ether” WHERE (“Producer” = ‘cvt-one-guru’ AND “name” = ‘HundredGigECtrlr0/0/0/2’) AND time >= now() - 15m”
epoch:“ms”
data:null
precision:“ms”
response:Object
results:Array[1]
0:Object
statement_id:0
series:Array[1]
0:Object
name:“Cisco-IOS-XR-pmengine-oper:performance-management/ethernet/ethernet-ports/ethernet-port/ethernet-current/ethernet-second30/second30-ethers/second30-ether”
columns:Array[2]
values:Array[90]
0:Array[1590005319427,100.00]
1:Array[1590005329427,100.00]
2:Array[1590005339451,100.00]
3:Array[1590005349426,100.00]
4:Array[1590005359429,100.00]
5:Array[1590005369423,100.00]
6:Array[1590005379457,100.00]
7:Array[1590005389411,100.00]
8:Array[1590005399405,100.00]
9:Array[1590005409432,100.00]
10:Array[1590005419422,100.00]
11:Array[1590005429444,100.00]
12:Array[1590005439414,100.00]
13:Array[1590005449440,100.00]
14:Array[1590005459418,100.00]
15:Array[1590005469407,100.00]
16:Array[1590005479465,100.00]
17:Array[1590005489421,100.00]
18:Array[1590005499430,100.00]
19:Array[1590005509410,100.00]
20:Array[1590005519413,100.00]
21:Array[1590005529424,100.00]
22:Array[1590005539424,100.00]
23:Array[1590005549455,100.00]
24:Array[1590005559420,100.00]
25:Array[1590005569426,100.00]
26:Array[1590005579425,100.00]
27:Array[1590005589448,100.00]
28:Array[1590005599432,100.00]
29:Array[1590005609436,100.00]
30:Array[1590005619435,100.00]
31:Array[1590005629411,100.00]
32:Array[1590005639431,100.00]
33:Array[1590005649424,100.00]
34:Array[1590005659458,100.00]
35:Array[1590005669425,100.00]
36:Array[1590005679423,100.00]
37:Array[1590005689433,100.00]
38:Array[1590005699423,100.00]
39:Array[1590005709463,100.00]
40:Array[1590005719440,100.00]
41:Array[1590005729445,100.00]
42:Array[1590005739424,100.00]
43:Array[1590005749440,100.00]
44:Array[1590005759444,100.00]
45:Array[1590005769426,100.00]
46:Array[1590005779465,100.00]
47:Array[1590005789429,100.00]
48:Array[1590005799454,100.00]
49:Array[1590005809420,100.00]
50:Array[1590005819420,100.00]
51:Array[1590005829412,100.00]
52:Array[1590005839435,100.00]
53:Array[1590005849445,100.00]
54:Array[1590005859449,100.00]
55:Array[1590005869455,100.00]
56:Array[1590005879418,100.00]
57:Array[1590005889441,100.00]
58:Array[1590005899447,100.00]
59:Array[1590005909437,100.00]
60:Array[1590005919470,100.00]
61:Array[1590005929428,100.00]
62:Array[1590005939444,100.00]
63:Array[1590005949428,100.00]
64:Array[1590005959441,100.00]
65:Array[1590005969439,100.00]
66:Array[1590005979435,100.00]
67:Array[1590005989445,100.00]
68:Array[1590005999435,100.00]
69:Array[1590006009444,100.00]
70:Array[1590006019443,100.00]
71:Array[1590006029451,100.00]
72:Array[1590006039420,100.00]
73:Array[1590006049436,100.00]
74:Array[1590006059450,100.00]
75:Array[1590006069439,100.00]
76:Array[1590006079476,100.00]
77:Array[1590006089422,100.00]
78:Array[1590006099430,100.00]
79:Array[1590006109434,100.00]
80:Array[1590006119432,100.00]
81:Array[1590006129422,100.00]
82:Array[1590006139441,100.00]
83:Array[1590006149453,100.00]
84:Array[1590006159417,100.00]
85:Array[1590006169464,100.00]
86:Array[1590006179431,100.00]
87:Array[1590006189443,100.00]
88:Array[1590006199430,100.00]
89:Array[1590006209439,100.00]
