Hi.
I’m trying to create a new alert, but always return “no data” message. The query is working and returning data normally. How to create an alert properly? Some screen shots:
Test rule result:
> "firing": false,
> "state": "no_data",
> "conditionEvals": "false = false",
> "timeMs": "2.358ms",
> "logs": [
> "message": "Condition[0]: Query",
> "data": {
> "from": 1597150937665,
> "queries": [
> "refId": "A",
> "model": {
> "alias": "GERAÇÃO",
> "groupBy": [
> "params": [
> "$__interval"
> "type": "time"
> "params": [
> "null"
> "type": "fill"
> "interval": "",
> "orderByTime": "ASC",
> "policy": "default",
> "query": "select * from \"POTENCIA_GERAL\" WHERE $timeFilter ORDER BY time ASC",
> "rawQuery": true,
> "refId": "A",
> "resultFormat": "time_series",
> "select": [
> "params": [
> "value"
> "type": "field"
> "params": [],
> "type": "mean"
> "tags": []
> "datasource": {
> "id": 1,
> "name": "InfluxDB"
> "maxDataPoints": 0,
> "intervalMs": 0
> "to": 1597151237665
> "message": "Condition[0]: Query Result",
> "data": {
> "series": [
> "name": "GERAÇÃO",
> "points": [
> null,
> 1597150941
> null,
> 1597150946
> null,
> 1597150950
> null,
> 1597150955
> "message": "Condition[0]: Eval: false, Metric: GERAÇÃO, Value: null",
> "data": null
You’re getting data. I don’t see the No Data error in the UI.
Try setting the For field to something lower. Right now, you’ll only get the alert if it is firing for a full 2 minutes.
