Using Latest Treemap on Grafana 7.3 Failing can't find panelbg
I have a Grafana 7.3 , MySQl 5.7…I am running an older version of Ubuntu 16.04.7 LTS.
Treemap by marcusolsson is loaded (0.5) and keeps failing with message “Cannot read property ‘panelbg’ of undefined.”
Thinking maybe I messed something up in my system I did a fresh install on another machine running Centos 7.9, just updated today.
Posted premarurely. Fresh install saw the same issue.
Little more background…I am confident my query is producing a good data set for the visualization as initially it worked. The colors were stuck on a green gradient that washed out the text and when trying to enter the Dimension section to change coloring that failed and went to a black screen “error”.
On the fresh install/different server it went straight to the “panelBG” issue. It never worked there.
Any help would be appreciated.
Hi, I’m the author of the plugin. If you’re still having issues, please submit an issue on the project page:
