I tried to enabled an unsigned plugin so I’m able to install it in the gui.
I’m with Grafana 8.2.2 on a Debian 11 bullseye server.
The Plugin it is about is check_mk as a datasource.
Since grafana 8.0 it is nesseccary to enable unsigned plugins.
I’ve done this by adding the plugin name in the grafana.ini behind allow_loading_unsigned_plugins
so this point of grafana.ini locks now like this ;allow_loading_unsigned_plugins = checkmk-datasource
The plugin I’ve installed by following command
cd /var/lib/grafana/plugins/ && git clone https://github.com/tribe29/grafana-checkmk-datasource.git
like it’s described here
everything seems fine but the plugin is not showing in the gui.
Any idea what’s maybe wrong in that way?
best regards
thanks a lot. didn’t recognized that the
