8.2.5, RHEL 8.4 -
A field in the table contains “instances” which are URLs. I want those URLs to take me to the URL I see. -
I am Overriding fields with Name = “instance” with a Data Link of${__data.fields["Instance"]}. I have also used${__data.fields.Instance}with the same result. -
What happened?
As an example, an instance ofexample.comlinks tohttp://my-grafana-server.com:3000/example.com -
The link of the instance withexample.comwould point tohttp://example.com -
URL variables | Grafana Labs
If the URL is fully qualified with http:// or https:// then it should work as you expect.
So you would need to either ensure your URLs in your source data are qualified or if you know that all the URLs are always either http:// or https:// or it does not matter then change your data link to one of:
http://${__data.fields["Instance"]}
https://${__data.fields["Instance"]}
