Table data link URL is always encoded and not usable
    9.1.6
    create a url in a table cell
    using table data link
  • What happened?
    link got encoded
    regular url
    https://${__data.fields[14]:raw}/query/defects.htm?project=${__data.fields[“data.project”]:raw}&cid=${__data.fields.CID}
What are the values of the fields?
https://sjc-xxx-coxx.domain.com:8443/query/defects.htm?project=%EF%BB%BF%EF%BB%BF%EF%BB%BFbranch_dev-xxx-family%EF%BB%BF%EF%BB%BF%EF%BB%BF&cid=%EF%BB%BF2xxxxx7
The expected URL should not be encoded.
please provide the data samples not the encoded url
__data.fields[14]=sjc-xxx-coxx.domain.com:8443
__data.fields[“data.project”]=branch_dev-xxx-family
__data.fields.CID=2xxxxx7
wonder if percentencode would work better than :
This one doesn’t make the link clickable: https://${__data.fields[14]:percentencode}/query/defects.htm?project=${__data.fields[“data.project”]:percentencode}&cid=${__data.fields.CID:percentencode}
and this one always got encoded https://${__data.fields[14]}/query/defects.htm?project=${__data.fields[“data.project”]}&cid=${__data.fields.CID}
what do you get when you right click on one of the data links and copy paste it to your browser ?
https://sjc-xxx-coxx.domain.com:8443/query/defects.htm?project=branch_dev-xxx-family&cid=2xxxxx7
This is what I get when right click and copy based on data you provided
Also the fact that it encodes it might mean you have data with spaces
This is the URL that I copy from the table cell
where is your data coming from? what is your data source
I think there might be spaces in the source data
Open the source data in notepad++ and check
The data source is Elastic Search. I checked with various tools (Explore, export CVS …) There is no space around the actual values.
checkout the data using notepad++
I downloaded and also use these tools to confirm that no space around the values. Is there a way to avoid this or is it a bug in Grafana Data Link?
EF BB BF is byte order mark for UTF-8 encoding. It may indicates a problem with site encoding, maybe user forces different encoding on the browser level, maybe ES didn’t correct encoding, … Remember that you may see sjc-xxx-coxx.domain.com:8443, but there can be non printable characters around.
Do we have a workaround for Data Link to use the values without trying to encode (the chars that we don’t know if existed and see) ?
in notepad++
When you click on
I would submit this as a possible bug but imho not sure it is the responsibility of grafana to account for every possible data variations but worth asking
I wouldn’t say that is a Grafana bug unless you can prove it. Reproducible example is not provided. There can be millions things, which can be misconfigured, e. g. reverse proxy for Grafana, Es, which provides incorrect encoding and then Grafana just doing correct UTF and url encoding.
Same problem to me .
my link definition
  • environment=“PRE”
  • arq=“X86”
What grafana opens is this link:
https://mygrafana.server.in.my.corporation.com/d/tablespace_ocupation_history/tablespace-ocupation-history?orgId=1&var-environment=PRE%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF&var-arq=%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BFX86%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF&var-db=MYDBNAME
IT seems that it is only happening with dashboards variables. the "&var-db=${__data.fields[“DB Name”]}" is passing it well. It seems something related only to generic dashboards variables.
I had exactly the same problem while adding a link to another grafana dashboard. And the problem seems to be in encoding - but I could not nail it down.
not working ling (adding %BB%BF)
https://testresults.qt.io/grafana/d/3dhio4K7k/fastcheck-ci-test-info?var-testCase=${__data.fields.testCase}&var-testFunction=${__data.fields.testFunction}
working link:
link do dashboard demonstrating behavior
https://testresults.qt.io/grafana/d/8ZVtdPf4k/grafana-adding-extra-characters-to-links?orgId=1&from=now-30d&to=now
ps that’s one of many examples of issues with working on grafana - a small issue, taking 2 hours roughly, that makes configuring and making the dashboard ‘client quality’ a frustrating experience
