Usage of plugins
hello all,
Is there a way how to identify in which dashboards which plugins are used?
reason for question:
after upgrade from 6.4 to 7.4 plugin peak report (Peak Report plugin for Grafana | Grafana Labs ) stopped working. the plugin is deprecated, that`s clear.
but I would really like to know in how many and which dashboards this plugin was used.
thank you
Use 3rd party GitHub - panodata/grafana-wtf: Grep through all Grafana entities in the spirit of git-wtf. and “grep” panel type name across all dashboards:
grafana-wtf find btplc-peak-report-panel
Each dashboard panel has type property, where used panel type is stored, so just “grep” it.
@jangaraj : exactly what I was looking for.
thx a lot :wink:
