I installed a couple of days ago K6 cli following Installation
Lately i’ve runned a system update and this message is shown.
Err:10 https://dl.k6.io/deb stable InRelease
The following signatures were invalid: EXPKEYSIG C780D0BDB1A69C86 k6.io (key for signing binaries) <security@k6.io>
This should be fixed now. We’ll discuss this internally and improve our processes to prevent this from happening again. Apologies for the inconveniences it caused and again, many thanks for reporting the issue.
Hey @Fred,
can you please do a more accurate report on your issue?
Did you follow the instructions for installing on Ubuntu? What command is failing for you? Are you updating or doing a fresh installation? Any details you can add regarding the context will be useful for helping you.
judging by your screenshot and the gpg: keyserver receive failed: No name error, it seems there is some connection issue between your machine and the Ubuntu keyserver, or the keyserver itself is flaky, which is a common issue, unfortunately .
As a workaround, you can also download the GPG key from our package server dl.k6.io, and then import it into the keyring. The complete installation instructions in that case would be:
The important thing you should see in the output is:
gpg: keybox '/usr/share/keyrings/k6-archive-keyring.gpg' created
gpg: key 77C6C491D6AC1D69: public key "k6.io (key for signing binaries) <security@k6.io>" imported
gpg: Total number processed: 1
gpg: imported: 1
From your screenshot I see that you have added the correct key to the /etc/apt/trusted.gpg keyring, but not to the /usr/share/keyrings/k6-archive-keyring.gpg keyring which is specified in the APT sources list. I reckon that if you change the signed-by value in /etc/apt/sources.list.d/k6.list to be /etc/apt/trusted.gpg, you would be able to install k6 without an issue as well.
