Hi, I’m using the instructions for ubuntu on Installation and I’m getting gpg: keyserver receive failed: No data error during install. I tried a different key server hkps://pgp.mit.edu and got the key file but it seems be wrong as then I got the following error
Err:4 https://dl.k6.io/deb stable InRelease
The following signatures were invalid: EXPKEYSIG C780D0BDB1A69C86 k6.io (key for signing binaries) <security@k6.io>
thanks. the issue seemed to have resolved by itself after a few hours. this happened in our circleci flow and since it uses a new image/container each time, it’s probably not an issue with cached key and most likely the keyserver is just flaky
