Hi Team,
I am not sure when this stopped working (looks like the key expired in March), but I was updating my k6 package today via dnf and it failed with the error below:
$ sudo dnf install k6
Last metadata expiration check: 1:19:07 ago on Sat 06 May 2023 07:37:05 BST.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
k6 x86_64 0.44.0-1 k6 23 M
Transaction Summary
Install 1 Package
Total size: 23 M
Installed size: 48 M
Is this ok [y/N]: y
Downloading Packages:
[SKIPPED] k6-v0.44.0-amd64.rpm: Already downloaded
error: Verifying a signature using certificate C5AD17C747E3415A3642D57D77C6C491D6AC1D69 (k6.io (key for signing binaries) <security@k6.io>):
Key C780D0BDB1A69C86 invalid: key is not alive
because: The subkey is not live
because: Expired on 2023-03-12T10:49:15Z
k6 5.2 MB/s | 5.3 kB 00:00
GPG key at file:///etc/pki/rpm-gpg/RPM-GPG-KEY-k6-io (0xD6AC1D69) is already installed
The GPG keys listed for the "k6" repository are already installed but they are not correct for this package.
Check that the correct key URLs are configured for this repository.. Failing package is: k6-0.44.0-1.x86_64
GPG Keys are configured as: file:///etc/pki/rpm-gpg/RPM-GPG-KEY-k6-io
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: GPG check FAILED
I have tried removing the repo and removing the old gpg key and then reinstalling but I still get the same error (gpg key looks the same as well)
I wanted to raise this here in case it was not a known issue
