Update panel legend values with custom name
Screenshot 2023-03-21 at 10.17.15 AM
Hi everyone, I have created a panel showing api frequency and added aggregation over panel legend to show count of frequency which is described using word “Value”. Is there any way to replace that word “Value” with word “Count” in panel legend ?
Hi @anurag15,
Yes, it is possible to change the Legend name.
I attached a screencast (open it in a new window as will be easier to zoom in and view more clearly)
override
Let us know if this helps.
Also, a side question, what is your DataSource for this Pie chat ? (as it looks cool!! :sunglasses:)
Hello there.
Resurrecting and old thread but I have the exact same problem as the OP. Whatever I do, there always will be “Value” on the legend of the pie chart. It’s either on top of the right column and there is a “Value” on the left of every value.
Override/Display name somehow doesn’t work: Depending on the columns I choose on the override settings, it either changes the name of every name to “xyz” or it just doesn’t change anything on the right column.
I cannot remove or rename the “Value”
I’m having the same problem: I need the legend ‘header’ to say ‘Count’ rather than ‘Value’, as I have monetary value elsewhere, and having a pie chart with a count of items say ‘Value’ is too confusing.
please try Organize fields transformation
use add field override select the field then change display name.
